to set xscale minimum with date time value
I have to work with a graph in which x axis is date time and i have used auto scae.
I want my graph to be plotted starting with the date time vale in the database.
I got the value also.But i could not write that value to xscale minimum .
Xscale minimum is accepting only double type value.
My date time value is in string format.
I tried to use scan from string function,but if i am converting to double its only taking the day vaue(ie,if10/10/2006 12:00:00AM,its taking 10 only)
Can anybody help me?
(2,752 Views)
Hi user_1,
have you tried to use some 'scan from string' functions before? (The AM/PM correction is maybe wrong, I prefer the 24h time format as well as all my measurement setups 🙂
Message Edited by GerdW on 03-21-2007 10:39 AM
(2,748 Views)
Thank you for the information..
I fixed the problem by converting date time to NI format(by coding ofcourse),it will convert date time to double format
then everything worked well.
(2,741 Views)
