to read structure variable from a binary file
Hi Everyone,
Iam having a binary file created by c++.It contains structure  like this one...
struct
      char name[2];
      unsigned short num;
      char identity[4];
      double date;
      union
          byte id[4];
          int sizeconst;
          int size;
I want to read this struct file in labview. How can i do that?
(2,379 Views)
Once I had the same problem, I've asked NI-support and they said to me because of different kind of reading method that that operation is impossibile to do, so the solution to solve the problem has been to create a C++ library that reads the structure from the file and makes disponible the data. After, I've called the library by "Call by library function" in my Labview software.
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
(2,372 Views)
