04-30-2018 04:25 AM
How i can to put variables in sql request?!
Thank youu for your help.
Solved! Go to Solution.
04-30-2018 06:25 AM
04-30-2018 06:29 AM
This is exactly what I was looking for
Thank youuuuu
04-30-2018 07:09 AM
I'm sorry to disturb you but, why I get commas instead of points in the result?
04-30-2018 02:05 PM
LabVIEW uses your regional number formatting settings from Window.
For instance your Windows is set to French, then you use a "," (comma) as number decimal separator instead of a period that you would get if you used English (US).
04-30-2018 03:27 PM - edited 04-30-2018 03:28 PM
Its better to use bound parameters if your SQL library supports it. String formatting may work for "input 4"="jcarmody", but will fail for "jcarmody's". Even worse is "jcarmody');drop table Banc2".
05-01-2018 06:11 AM
@drjdpowell wrote:
[...]Even worse is "jcarmody');drop table Banc2".
Oh. Yes. Little Jimmy Tables, we call him.
exploits_of_a_mom
