to more specific class: Cant find strict numeric, only numeric
Im trying to read a control property by reference from some controls that are in a cluster.
I want to cast the property's reference to a more specific class: strict numeric, but I can only find 'Numeric' which leaves me with variant data.
Any help?
(4,982 Views)
Accepted by topic author _Faust
Right-click on the control terminal, then create a reference. Wire this reference to the "target class" input of the cast node.
Paolo
(4,968 Views)
I think you can't (not fully sure though). What you can do is get the "Representation" property, that tells you if it's I32 or DBL or else (as an enum) and with this information you can get the value from the variant.
See :
Hope this helps
EDIT :
Oh... I see now that there IS a way, thanks for that pincpanther 😮
Epictetus
Antoine Chalons
(4,962 Views)
Well, I meant right-click on the control. Obviously, a control in a cluster has no terminal 🙂
Paolo
(4,954 Views)
Thank you both very much for helping me out!
(4,906 Views)
