to customize a horizontal "meter control" to vertical
i want to modify the available "meter control" i.e at the moment it is in tthe horizontal position i want it to be in the vertical position , tried it in the customizing control but could not
(2,874 Views)
I think you will have better luck starting with a gauge control, using
the selection tool to move the outer scale ticks where you want, then
coloring or hiding the pieces you don't want to see. Unfortunately, the
meter is a troublesome control that has lots of ratios and things
hard-coded.
Greg McKaskle
(2,874 Views)
Hi Greg ,
i tried wat u said but the effect is not satisfactory,i have attached a bitmap file explaining precisely wat i want .
Regards ,
Tanisha
(2,874 Views)
