timing while loop with resolution less than one second
I am trying to time a while loop using "elapsed time.vi", but I can only get a resolution of 1 second. Could anyone please tell me is there any method that is able to measure the execution time of a while loop with a resolution of 0.1 or 0.01 second? Thank you.
Yang
(4,125 Views)
Hi Yang,
You could use two tick count.vi's. One before the loop and then one after the loop executes. This gives millisecond resolution. See the followin thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=121328&query.id=11484#M121328
Cheers,
--Russ
(4,121 Views)
Yang,
Russ is right, but one or even several milliseconds are quite a long time for recent CPUs, I know there is an interface to a Windows-DLL that gets the actual CPU timer, which give the resolution of the PC crystal clock (usually much much less than 1 µs). I could dig if this is reall necessary..
Greetings from Germany!
Uwe
(4,111 Views)
Hi Russ,
Thanks a lot. Now I get it. You are so helpfulSmiley Happy
Yang
Message Edited by YangLi on 05-10-2006 06:01 AM
(4,100 Views)
Hi Lul,
You'll be my saviour if there is a method like that, which would be a  solution for another problem that I ve been seeking for long time! I used to think there was no way to measure time with resolution less than 1ms using soft timing. Could you please explain the method? I would like to see whether it can be used to measure a duty cycle with a 1ms period. Maaaany thanks..
Yang
Message Edited by YangLi on 05-10-2006 06:03 AM
(4,099 Views)
The first link I found is this:
http://sine.ni.com/apps/utf8/niepd_web_display.display_epd4?p_guid=B45EACE3E68356A4E034080020E74861
As it explains everything it should be sufficient to point you toward that.
Uwe
(4,087 Views)
