timing problem highligth modus work
got the timing problem
(3,052 Views)
Please Check with your code Prototype
Based on your Explanation First Warning comes when your counter is Lower than 2 then you should have the Limit for Upper Value, Like the same for Another warning both warning should have both upper and Lower Limits to decide the type of warning
(3,045 Views)
