timing loop
Hi, Thanks for all the help so far. But I have another silly question. On the same program, when I try to run it with the while loop, the Q values are not updated, meaning that the call library functio node is not running more than once. I can see that the real and imaginary values keep changing on the front panel, whereas the Q values remain the same after one iteration. But when I remove the while loop and hit run continuously, the Q changes as well. Is there a way  to do that with any of the loops?
Message 11 of 12
(652 Views)
I think I found the problem.. Adding a delay did the trick 🙂
Message 12 of 12
(644 Views)
