timestamp
In labview 8.5, how can I plot a discrete signal, i.e. not a waveform, vs. a timestamp?  I am trying to take a waveform then average it and plot the averaged values over time.
Thanks!
(4,258 Views)
Accepted by topic author adwhit
Convert the timestamp to a DBL and use it as the X axis of an XY graph.
Message Edited by Dennis Knutson on 03-18-2010 01:54 PM
(4,253 Views)
Hi adwhit,
take a XY graph. Make an array of timestamps for the X values. Make an array of numbers for the Y values. Bundle the arrays to a cluster. Wire the cluster to the graph. That's what the context help of the graph says! Now the only step left is to format the x axis to show time instead of numerics...
(4,248 Views)
Gerd,
We have to stop meeting like this.Smiley Very Happy
(4,238 Views)
Thanks for the help, the graphical solution was very helpful!
I now want to take a running derivative, or linear fit to determine equilibrium... any ideas on that?  I'm just not sure how to do the running part the best way.  I need to take probably the last 1200 samples once I have that many, or all the samples before I reach 1200.
Thanks again.
Adam
(4,178 Views)
Hi adwhit,
just search the forum for "running average" or "running mean" - you will find a lot of threads already with solutions...
(4,173 Views)
Ok, thanks a bunch.
(4,171 Views)
