timed loop miss some items
Hi all,
I am using cRIO 9025 AND NI 9203 to sample from seven current channels at 1000 Hz. I wrote the data with timestamp into a file. However, it seems that the sampling is not continous.
As you can see from the text file attached, the time stamps for the fisrt sample and the second sample have a difference which is 3 ms. Then this would happen every 208 samples. If you open the file with Notepad++, you would see it clearly.
And I found that if I decrease the number of channels from 7 to 1, the problem would happen every 656 samples which is very wierd.
I try my best but still can't understand why this happens. Could you please help me have a look at the VI?
Thank you very much.
(3,346 Views)
From looking into the VI, i can only guess why the "time jumps" occur so "deterministic".
But it is quite obvious to me that some things can be optimized which maybe can already remove the issue:
- Eliminate redundant code (taking timestamp).
- Remove unnecessary computations (select function, feedback for dt and false-constants).
- Stick to one datatype (change the offset and scale to double).
- Never ever compare doubles as equal/not equal!
- Split up logging from acquisition into different loops. Use RT FIFOs instead of normal queues.
I assume that the "time jumps" are generated by finished late iterations and the setting to maintain the phase and to discard missed iterations....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,331 Views)
Thank you for you help.
You are right. The "time jumps" are generated by finished late iterations and the setting to maintain the phase and to discard missed iterations. I unchecked these two options in the configuration of the timed loop and got the right sample times (i.e. 1000 samples in one second). While the period is not exact 1 ms sometimes, as you can see in the shot below. Is there some method to fix the period to be exact 1 ms?
Thank you very much!
(3,315 Views)
I assume that you still use a single loop for acquisition and logging. Split it up. Use an RT FIFO to transfer the data (aka producer/consumer framework, similar to the one used on Windows systems) to a parallel running loop which does the logging. I am quite confident that those finished late iterations are generated by the access of the flash.
hope this helps,
Norbert
EDIT: If you take a close look at the screenshots, you will find out that the timestamps <1ms are always there when the timed loop is "catching up" a finished late iteration. The easiest thing to avoid this is the info i have already written in this posting.
Norbert
Expert: Geometry
(3,291 Views)
