timed daq using timed loop
I am very very new to labview 8.5 and the whole daqmx thing, i am reading all the stuff here and there but still can't figure out how to build my VI... What i want is the following:
1. A contineously acquisition of 8 channels with a sample frequency of 500 Hz, stored in a file (EDF) every 1 second. For this i can use a simple daqmx assistant that aquires the samples and update the loop every 1 second. I already wrote the EDF thing.
2. Another loop that displayes the data that is coming into my hardware realtime with a higher refresh rate, lets say an updated screen every 25 ms.
Now i was wondering if there is a way to connect the counter of the onboard hardware clock on my USB6215 to an input on a timed loop, so that my timed loop is hardware timed, if that is possible i can make a loop inside a loop where i can write my data every 20st iteration that is exactly (20 * 25) 500 samples...
Thanks in advance,
Thijs Boeree
(4,917 Views)
In the link below you have some information about Timed Loops Configuration in order to have an external timing source.
https://www.ni.com/docs/en-US/bundle/labview/page/configuring-timed-loops-and-timed-loops-with-frame...
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(4,907 Views)
Thank you, i've red the page, but it didn't resolve my problem... I also tried to use "DAQmx Create Timing Source" but this only gives an erro that my device can't work with that?
I really don't know what to do.
This
(4,902 Views)
Here you have an example VI for Timed Loop with external clock. Note that I use the counter with digital edge with counter and not directly the onboard clock. Hope this can solve your problem.
    Benjamin R.
(4,892 Views)
I always get this error:
Possible reason(s):
Measurements: Requested value is not a supported value for this property.
Property: SampQuant.SampMode
You Have Requested: Hardware Timed Single Point
You Can Select: Finite Samples, Continuous Samples
Task Name: _unnamedTask<6>
Has this something to do with my USB6215
Thijs
(4,887 Views)
Hi Thijs,
Looking at the examples above you are timing Digital I/O. Currently due to hardwate limitation the Hardware Timed Single Point sample mode is not supported on digital I/O.
You can only use Finite Samples or Continuous Samples on a Digital I/O task.
Karsten
(4,855 Views)
Hi there,
Thank you for responding to my question. I already tried some examples with hardware timed looping and my ni-USB6215 but i get an error message that my device doesn't support some things. If i can't get a loop hardware timed, i have to do it on another way...
This is what i hope you can help me with...:
One program with data-acquisition (analog in 500 Hz 8 channels) update every 1 second (the aquired data needs to be writen one block of 8 * 500 samples every second to a file).
Then another loop...? with the same data but then updated every 25ms, so that i have a smooth scrolling display of my incoming data.
I know the basics of labview and already have writen such a program in labview 6.0 but back then i could also got another analog input VI in my block diagram with the most recent aquired data, i also used daq occurence.
I hope you can help me with the basics of daqmx, one loop updates every 1 second (hardware timed) and the second loop updates every 25 milisecond (for displaying smooth scrolling data).
Thijs Boeree
(4,847 Views)
