Hi Ash,
most of the delay occurs before acquiring data to initialize the card.
Since you have a trigger you should use the intermediate Analog In VIs. There you can configure your card to use a trigger signal. So you can synchronise your high speed film and your DAQ Card by the hardware pulse. A good way to start is the LabVIEW measurement manual Chp. 6>>Bufferd Waveform acquisition>>Simple buffered analog input examples.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
