time stamp to number function
The Conversion VIs and Functions palette has a function that converts the number of seconds elapsed to a time stamp (To Time Stamp Function).  I need to go in the other direction, from a time stamp to a double (number of seconds elapsed since 12:00 a.m., Friday, January 1, 1904 Universal Time).  Does anyone have a function to do this?  I've tried to type cast with no success.
Steve Hall
stephen.hall@parker.com
Message 1 of 11
(56,014 Views)
Accepted by topic author parker_irvine
Just use the To Double Precision Float function. It's polymorphic and it will accept a timestamp to return the number of seconds since the LabVIEW "zero-time".
Message 2 of 11
(56,014 Views)
That is really helpful. Now,  how do I convert the numeric back to a timestamp?
Message 3 of 11
(43,232 Views)
OK, I'll answer my own question.  There is a VI called 'To Timestamp' in the time pallet which does the job beautifully.
Message 4 of 11
(43,228 Views)
I need your help. I want to collect timestamp in format of  03/24/2016 07:20:01  for each of data. I did coding in a way as timestamp file. But my output data is different format. It shows fraction in second value. I changed it several ways and it did not work. Can you please help me?
Message 5 of 11
(40,490 Views)
Why don't you post your vi instead of two pictures that have absolutely no relation to each other?
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(40,477 Views)
What format are you saving the file in?  Could you give us a VI so we can see your settings for the Write Measurement File?
Message 7 of 11
(40,448 Views)
You do know that you can right click on the top of a column in Excel and select "Format Cells" and chage the time/date format in your spreadsheet, right?
Personally I just dump the "raw number" into excel and format it like I said above because I may or may not want the date included.
I use this little VI to add a time stamp to data as I save it.
As I said the raw time stamp will look like this in Excel
With a couple clicks of the mouse in Excel it can look any way you want.
=== Engineer Ambiguously ===
Message 8 of 11
(40,425 Views)
Thanks.
But I guess, I have another problem. I need to collect data for every second and write to file. But how can I control the time in write to measurement file?
When I collect data as the attached file it gives the data in every 0.833second. But I need to collect for each second. My question is how to write measurement file every second?
Message 9 of 11
(40,376 Views)
You need a timer in your loop so it only reads the frequency and saves it once per second
Message 10 of 11
(40,309 Views)
