time scaling
How can I perform Time scaling on a signal like getting X(2t) or X(t/2) from x(t) in labVIEW. PLease reply quick.
Message 1 of 10
(4,317 Views)
extract the time from the waveform, scale it, add it back in....
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
Message 2 of 10
(4,315 Views)
Hi TWGOMEZ
Thanks for the reply. but tell me one thing , Im reading the simulated waveform from .txt file and I want to time scale this waveform . Im attaching the VI and the required text file. I want to time scale the waveform coming to the waveform graph. Pls help.
Message 3 of 10
(4,287 Views)
Since you do not have timing data to the text file, you can add it this way with the Build Waveform function.
Message Edited by Dennis Knutson on 05-03-2008 08:23 AM
Message 4 of 10
(4,270 Views)
Thanks Dennis.
I want to scale only a part of the waveform and then replace the orginal part with that scaled part. How shal  I go about it?? Pls reply.
Message 5 of 10
(4,237 Views)
I don't quite understand. By definition, a single waveform has a uniform dt. What exactly are you trying to do?
Message 6 of 10
(4,218 Views)
In simple terms I just want to expand/contract a part of a waveform
Message 7 of 10
(4,202 Views)
Use an XY graph, and do basically the same thing as shown above, but dT being X is an array that you can add whatever values you want, each one corresponding with the same index of Y...
Message 8 of 10
(4,187 Views)
This simplest way would be to just use the zoom function on the graph palette. You can also change the min/max settings of the graph with a property node.
Message 9 of 10
(4,176 Views)
Thx TWGOMEZ
But can you put up an example for that??
Message 10 of 10
(4,146 Views)
