time reset
The following VI generates a random number and the time starts when the value generated is between two specified values. How could I modify this Vi to have the elapsed time reset to zero every time the random number is between those two values instead of continuing counting?
Thanks in advance
Valls
(3,411 Views)
If I understood you correctly, all you need to do is wire a TRUE to the "Reset" input, and then use a shift register to pass out the "Present (s)" output to use as the value to pass into the "Set Start Time (s)" input. See attached.
(3,401 Views)
Forgot one little thing: The shift register should have a constant of 0 wired to it to initialize its first value.
(3,400 Views)
It works great! thanks!
(3,375 Views)
