time recording
Hi all,
I want to loop start time in HH:MM:SS and stop time also in the same format, which will be user entry in the program . but when i use elapsed time block i facing problem as its in seconds , how to solve this?
regards.,
Sanvi
(2,119 Views)
Hi sanvish,
Simple solution: apply some simple math!
Hint: when there are two inputs with data format of "HH:MM:SS" then you can easily calculate the difference and represent the difference in seconds…
(2,106 Views)
You can do math on time just like any other number.
Stop time - Start Time = Run time
While running:
Stop Time - Current time = Time left to run (countdown timer)
=== Engineer Ambiguously ===
(2,067 Views)
Is this what you are trying to do?
(2,055 Views)
hi
Thanks for giving time my query..but i am unable to access the file attached as i am using 2014 version ..can you please  send the file in lower version .
(1,999 Views)
Here's the 2014 version
(1,980 Views)
Here
(1,959 Views)
