time normalize
I already posted a question,but never tried the solutions suggested until recently.I am looking for a way to normalize the time on my different sets of data.(The "align waveform timestamps" doesn't work for my case.)
Each of my sets of data start and end at different times.I need a way to normalize the start and end times(so that everything has the same start and end times).Any suggestions?
(2,752 Views)
What doesn't work about the function? The function does make every waveform have the same start time. If your waveforms have different stop times that's because they don't have the same number of samples or the sample intervals are different. You can use the Get Waveform Components to view dt and the Y array to determine where the difference is. Once that's known, the Build Waveform can be used to modify either one - just like Align Wavform Timestamps does to t0.
(2,752 Views)
