time measurement when voltage is below a certain amount
In a project for class I built a pendulum that swings through an infrared emitter to a detector. when somethings cuts the beam from the emitter, the voltage drops to virtually zero.  I need to be able to measure how long the voltage was at zero for my project, but can't for the life of me figure out how to do it.  I really would appreciate any help!
(3,134 Views)
ramone2285,
What kind of hardware to you have available to make the measurement?  If it is a DAQmx device, then look at the Meas Pulse Width.vi example that ships with LV.
(3,129 Views)
i'm using a daq device (i'd have to be in class to tell the exact version).  I'm reading the voltage on a channel I made, and the voltage bounces from 0V to 1.6V when the beam is cut.
one idea i came up with was to setup a comparison where a caution/stop light would light up whenever the voltage was below 1V, and then have something measure how long that light was on, but I could find a vi that could do that.  I'll definitely give that measure pulse width thing a try, cuz I need to hurry up and finish this project already.
(3,118 Views)
ouni think I found a way to do it. I went through the help context and found an example of how to measure pulse width.  They say i have to create a channel on my Daq (NI Daq 6251) to do the readings, which ends up being on the PFI9 port. All I need to know now is how exactly do I get a reading from that port on the daq device? it only has one hole, so where is the negative leg of my wire supposed to go.
(3,080 Views)
ramone2285,
What wires are you connecting up?  I'm assuming you'd have the signal connected to the digital input and ground.
Jared Boothe
Staff Hardware Engineer
(3,045 Views)
