time loop accuracy
I haver some problems with the time loop structure. I try to get digital pulses of a width down to 50 microseconds! I have a real time OS on an PXI 8176 RT controller. For only one digital channel, this is not a problem, but the more channels I use in the time loop, the worse it gets. Is there any solution? What is the accuracy of time loops?
Tim
(3,035 Views)
Hello Tim,
please post an example what you are trying to do. So it is easier to understand your problem.
On the other hand it sounds reasonable:
The more number of channels you try to handle the higher system load you will get ...
Thomas.
Message Edited by Tobel on 01-17-2006 04:31 AM
(2,974 Views)
