time integral problem
I wanted to move my project from Matlab to Labview but I have some problems. I can received similar result just for dt=100ms. If I change it I cannot after received stabilization. What I want to do: I have a piston pump, which based on a linear motor and I would like to set new values of motion based on flow. More precisely I have desire flow and I compare with flow which I obtained and after I set motion of linear motor. Those described all modules in Labview.( in attachment a picture). Each modules are based on point-by-point integral where I have to set time integration dt. If I put different than 0.1s (100ms) I cannot achieve stabilization. Maybe somebody works with point-by-point integral and knows something about disadvantages that method? Thanks for any help.
PS. To see properly the picture you need acrobat reader and you have to do big zoom.
(4,009 Views)
Hi Tutenhamon,
Do you see this comportement with every other values or with higher/lower values?
You could also test with a normal while loop and not a timed while loop.
regards,
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,951 Views)
Thank you for replied. I see it with any values. I tried to changed it for any diffrent ways but I cannot achive stability above or below 100mS response time. What is for me strange. In Simulink it works fine but I have all drivers in Labview. I check it with normal while loop too. The same results.
(3,942 Views)
Tutenhamon,
Is it possible to send your VI so we can have a look at it? It will be easier to examine your code with the VI in front of our eyes. Smiley Wink
(3,905 Views)
Of course, with the pleasure 🙂
(3,900 Views)
Tutenhamon,
Do you know that you can include m-files directly inside LabVIEW? From 8.2, you can do it ! I give you two links to our website :
1) Inside LabVIEW MathScript
2) Working with .m file Scripts in NI LabVIEW for Text-Based Signal Processing, Analysis, and Math
I think it can help you because I can't see what you do wrong because I can't compare your LabVIEW code to MatLab code and more, I don't experience with MatLab. Sorry.
Best Regards,
(3,885 Views)
Thank you but I don't think if I can use it. I used the Simulink before, it isn't MathScript. I will try to find another way to control it.
Thank you anyway.
(3,881 Views)
