time input response
I have a Hydraulic solinoid valve energised by a digital output on my DAQ device (USB 6012)  holding a pressure measured by a transducer which is read into an analog input channel. I have to measure and plot the time taken from denergising the solinoid valve for the pressure to reach 0 i.e 0v. the average time for this is 70mS, will a elapsed time vi be good enough for this or do I need to use something else. Any guidence will be most welcome.
(2,917 Views)
Accepted by topic author alanled
Look in the
Help\Find Examples\Hardware Input and Output\DAQmx\Analog Measurements\Voltage and then pick for example the "Cont Acq&Graph Voltage-Ext Clk-Dig Start.vi" as a starting point.
The measured voltage is your pressure sensor
The Dig start is you digital I/O that drives the valve
Modify what has to be modified, but use this one as a start...
PS: There's maybe a better one in the list but I didn't check them all
(2,909 Views)
