time format
For a status report of the program, showing each command sended and the actions executed,  I want to introduce a time stamp at the beginning of each line
(4,874 Views)
I'm not sure about what exactely you're asking for...
If it's just about how to to get a date and time string then it's very easy... see attached picture.
Epictetus
Antoine Chalons
(4,871 Views)
I don´t know why, there are 2 messages created, one of them only with half text. Sorry about that. Here is the full one:
"For a status report showing each command sended and execution of the program, I want to add a time stamp in the beginning of each line of it. To obtain a more clear result, I want all characters in the same space, but I can´t achieve it due to the hour field, as shown in this example:
8:57:43 command example1
10:01:07 command example2
I have seen how to remove the leading zeros (with #) from minutes and seconds, but not how to add it to the hour, which is what I´m looking for.
I know that there is another option: split the string, analyze the hour and add a initial space if is under 10, but it looks a quite dirty solution. So I guess it can be implemented with the time format string. Somebody knows how?
Thanks."
Gatet
(4,866 Views)
Well then sory, I can't answer the full question... I'd use the string functions to fix it... Maybe there's a better way.
Epictetus
Antoine Chalons
(4,863 Views)
Thanks anyway, Titou.
By the way, I get the solutionSmiley Very Happy
(4,856 Views)
I see that this is an ancient thread but I'm having the same issue and the proposed solution does not work for me. I'm using a very similar format string (%H:%M:%S%2u) and it does not give me a leading zero for single-digit hours. Does anyone have a solution?
(4,337 Views)
(4,325 Views)
