time event marker problem
hello,
I need to write a program to save the time difference between start and events. If the event is to press the button manually, I can do that.(like the attachment). However, the event is controlled by the labview and also I need to separate between those 4 types of event. I trt to use the value function in the property node to control the switch inside the while node, but it doesn't work
Could you please teach me how to do that?
thanks
(2,585 Views)
Could you precise what are the 4 types of events you want to detect ?
Chilly Charly    (aka CC)
(2,585 Views)
