time domain analysis via onboard microphone on SPEDY-33
Huh? What do you mean?  This maxi. input working voltage is refering to??
Message 11 of 13
(599 Views)
BK Lian wrote:
Huh? What do you meanThis maxi. input working voltage is refering to??
Do you not read the documentation young man ;). Also check the settings for item 7 and 8.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 13
(597 Views)
Yes, I know that. I have adjusted the audio input level jumpers to the microphone level as shown in table 2-1. Hence, the value I'm getting on the waveform graph is from the two onboard microphones (not audio line-in).
The microphone will detect the ambient sound pressure and convert them to electrical energy which is the analog input voltage. Also, this microphone has a build-in gain too. Next, it will undergo a op-amp with a gain of 1.78. Lastly, this signal is converted to digitize value signal by a A/D convertor.
So, my question: Where is the maximum working for analog input refering to if I'm using the onboard microphones?
Message 13 of 13
(590 Views)
