time delays
Currently, I can successfully complete the following simple action:
upon running my VI, one LED comes on
after one second, a second LED comes on
after two seconds, a third and final LED comes on
because I can only place one input into the the LEDs, I do not see how it
would be possible to change all three boolean inputs to false after a given
amount of time. Any hints are much appreciated
Aaron
(2,559 Views)
Hello Aaron,
you can use local variables (right-click on terminal-> create -> local). Set the locals to writable, if they aren't. Use them like the original control/indicator.
And read the chapter on locals/globals in the manual!
You can do all this also without locals by using a (while) loop and a case-statement (aka state machine, look for that in the user group).
(2,559 Views)
