time critical triggered application
Hi all,
I have an application where data from a CCD camera are readout in a triggered mode. The CCD is connected by an USB2 to the PC.
My problem: the CCD running on labview misses a trigger (approx 1.5 Hz) once in while. If I run the camera in an untriggered mode it takes is possible to run it on 1.8 Hz. Labview takes about 99% of the CPU speed (1.8 Ghz PC) during the data acquisition.
Is there a chance that I could overcome my problem of missing triggers by
a.) mass compiling the Labview code (dll's from a third provider are included in the code)
b.) use a faster PC
c.) any other measure ??
I would be grateful for any suggestion.
Dirk
(2,487 Views)
First, let's clear a misconception. Mass-compiling is actually a mass conversion of an entire VI herarchy of old VIs to the current labVIEW version. It has no influence on speed if all your VIs are already saved in the current LabVIEW version. (Only a freshly converted VI from an old LabVIEW version is a bit slow until saved, so make sure that all subVIs are current)
A faster PC will help IF your problem is truly CPU limited. This is difficult to tell without looking at the code.
What else does your LabVIEW program do (e.g. processing and displaying the image at a high rate)? Is it possible that your code does a lot of unecessary work? How many parallel loops are there?
Are all front panels of SubVIs closed while runing unless they really need to be visible?
What else is running on the PC? Could it be frames are missed if other stuff happens (antivirus, windows updates, etc.). Are there any other USB devices on the same controller (e.g. USB mouse, etc.)?
Have you played with priorities? A typical VI will also speed up a bit if you disable debugging.
If you don't mind, post a simple version of your code. Is it clean and streamlined or cluttered with local varables and property nodes? Are heavy calculations only done when needed or with each loop iteration?
Message Edited by altenbach on 05-08-2005 02:25 PM
(2,483 Views)
