time counter...
Hi all....
How can I using labVIEW to create a stop watch for count the time? anyone have idea about this?
with regard
Jaxx
using labVIEW 7.1 on winXP
Message Edited by @ on 04-12-2005 11:10 PM
(3,060 Views)
If you are talking of a software stop watch you can directly make use of the "Elapsed time" express vi present in the time and dialog fuction pallet,else if you are talking of a hardware stopwtch then you will have to tell us what hardware you want to use and what is the action to be taken when the specified time is over.
cheers
vicky
(3,051 Views)
Hi Jaxx
Attached is a very simple stop watch.
If you push "Start/Stop" button time counting is started and it runs as long as this button is true.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,050 Views)
An addition to your answer vicky.
The express vi Elapsed Time uses a target time. If this time is reached it resets - so for a "real" stop watch, I wouldn't use it.
Thomas
Using LV8.0
(3,050 Views)
Hi vicky and Thomas,
Very thanks for you two's answer... i think i already got what i want at here, thanks again! 🙂
best regard
Jaxx
(3,044 Views)
