threshold range slide imaq vision
Hello..
But...i want know how can i put a slide for change the range of the threshold in this attachments?
and how can i do that ..automaticaly.....when i change the value of the range............the range automatically change in the image.?
Thanks so much.
Message 1 of 11
(4,778 Views)
Hello Eliel
First replace the cluster constant (Range Constant) in the block diagram of the attachment by a cluster control, then you substitute the numeric controls inside the cluster by horizontal or vertical Pointer Slider.
With the User Interface Event Handler design pattern (Event Structure) you'll be able to see the image modifications every time you hit the threshold button, if you want to see these changes more dynamically, when you click the threshold button once, I think you could use the State Machine design pattern. If don't know how the state machine design pattern works very well, please see the link below that's a tutorial about it.
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
Hope it helps you
Best Regards
Marcio Soares
National Instruments Brasil
www.ni.com/suporte
Message 2 of 11
(4,750 Views)
can you do that in my example VI, please.
Because i don't know how can i do that.
Thank You so much.
Message 3 of 11
(4,740 Views)
Accepted by topic author eliel
Like this?
Josh
Software is never really finished, it's just an acceptable level of broken
Message 4 of 11
(4,731 Views)
Hello Eliel.
Yes, this way also works, but you can just right click in the Range constant and select the option change to control from the shortcut menu. And then, in the front panel, you can right click in the numeric controls inside the cluster and select replace, to change them by the other types of controls like these ones you are already using.
like this in the attach.
Best regards
Marcio Soares
www.ni.com/suporte
Message 5 of 11
(4,729 Views)
That's Perfect.....
Thank You so much...!!!
Message 6 of 11
(4,723 Views)
You're welcome!
Marcio Soares
www.ni.com/suporte
Message 7 of 11
(4,705 Views)
Do you know how can i calculate the area of the Threshold?
Can i do that?...with my VI...i can measure the area..with the point tool...but when i click with the point tool in threshold image ..the software show me the total area...of the image.
Can i measure the threshold area with your .VI?
Thank You
Message 8 of 11
(4,701 Views)
are you brazilian?..
if you are brazilian can you speak in portuguese with me because i'm brazilian too...kk
Message 9 of 11
(4,700 Views)
Olá Eliel.
Podemos conversar em portugues sim!
Apenas para o melhor gerenciamento e facilidade nas respostas às suas perguntas, peço o favor de postar um nova pergunta em um novo fórum.
Obrigado
Atenciosamente.
Marcio Soares
www.ni.com/suporte
Message 10 of 11
(4,675 Views)
