thermal coupler error
I have an instrument that is using 2 thermal couplers. I set them up in labview using the DAQ assistant, works perfect, but when i put them in the same program there is a error. it says that there is already a device assigned that function. I made sure that they were assigned different input, so that is not the problem. Any help would be great.
(3,047 Views)
Thermocouple ???
If you post the error number, that would help.
Do you have more than one DAQ assistant and getting error -50103?  If so, then search http://forums.ni.com/ni/search?submitted=true&q=50103
(3,042 Views)
