the win32help.exe error when I use the help of LabVIEW .
I had installed the LabVIEW6.0 under the win2000.My computer has intel 845 motherboard and P4-1.5G CPU. When I open a vi and right click on a function vi for help. Then there will be a error"winhlp32.exe".I tried to install the LabVIEW and win2000,but there is no result.I don't know how to solve it.
I will really appriciate your help.
(2,450 Views)
It sounds like something bad happened during one of the installations that is causing the problem. You've tried re-installing both Labview and Windows 2000 but the same thing happens? Are you do any custom things in your installation?
Matt Kisler
http://www.ni.com/ask
(2,450 Views)
