the remote target is missing required components
I'm working with cDAQ-9174 usb chassis, NI9207 analog acquisition module, LabView2012 and I'm facing a very strange behaviour.
I create a blank VI, I put the Express->Input->DAQ Assistant VI on the block diagram and all works fine, that means that I obtain the usual wizard that guide me
through the installed hardware in order to choose type of acquisition (volt, ampere), channel, and so on.
If I do exactly the same thing inside a project (every project, also in a new blank project), when I depose the Express->Input->DAQ Assistant VI obtain an errore
message: "the remote target is missing required component".
There is no way, outside projects all works fine, also in MAX all is always fine, inside a project I'm facing this problem.
The problem is sporadic: in order to "fix" the problem I have to restart the PC again and again till the "good restart", when all works fine also inside projects.
At the moment LabView is installed on two PC and I'm facing the problem on both.
Thanks in advance for help.
Fabiano
(3,169 Views)
Hey Fabiano,
 maybe you can fix this problem by re-install the latest DAQmx driver.
Let us know, if this works.
CMW
(3,159 Views)
