teststand Vs Labview in using SQL
hi,
I am new to using database in Labview.
What I want to do is : Access the SQL database and get the data, send it to teststand, and send the result obtained from the teststand back to database.
I want to know which one to use labview or teststand to make database accessing and sending more flexible so that if want to change the architecture in future.
Presently I have a view like accessing the database through labview and get the data in required format and then send it to teststand. After running the sequence use teststand send the result back to database server.
I use labview 2009 and have database tool kit. Teststand 4.2
(3,123 Views)
duplicate post
It is really irritating to see the same post from you. This is the third time you posted the same question. Why are you doing this?
(3,064 Views)
