tempo
i wrote a vi to make a sequence in acquisition application with differents confirmation (quest1, quest2) before restarting a counter
but he start even if user doesn't confirm
i don't see how to make it wait for the dialog box output before continuing next index, exept for last (quest) that don't need confirmation it's just an
informative box
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,896 Views)
You need a relative time source, not a constant one.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,876 Views)
If I understood the question correctly, all you need to do is to wire the "Reset" input of your time function based on the while loop iteration count:
Message Edited by smercurio_fc on 04-21-2008 02:54 PM
(2,871 Views)
hello,
not exactly , but tanks to both suggestions i found how to do (see vi)
Best regards
 Tinnitus
(2,838 Views)
