template for main.vi loader
Usually I'm starting my my apps thru loader, similar to C++ style. It should handle things outside main.vi like: user access, check for updates, prepare data, store logs, etc.... Is there a template allowing to execute it most efficient way? Usually I'm running the app as dialog, I'm hiding panel from loader vi and at the end I close everything with quit labview.
(1,224 Views)
No Specific template for loading config files necessary for Main VI to RUN.
Basically you can develop a state machine where it will load all the necessary config files in init state and close in exit state.
(1,147 Views)
