temperature control using fuzzy logic
Hello I am building a temperature control system using Fuzzy PID, I am building a self tuning PID gains by a fuzzy logic algorithm, but the problem I know the rules for the parameters of PID but dn't know the approximate range in membership of each output . does any one have a small example jst to explain or help me determine the values knowing that I dn't have a real transfer function of the heater
(4,436 Views)
Hello, Can you give more informationa about the software you are using? Are you using the fuzzy logic toolkit?
Randy @Rscd27@
(4,381 Views)
thank you so much for replying ,yes I'm using the fuzzy logic toolkit
I'm trying to control the temperature of a heater(1st order system), using the fuzzy logic in labview to tune the PID parameters (kp,ki and kd) I know the rules to be used but I could not determine the member ship functions ranges. knowing that I will send the output of the fuzzy logic by the opc server to the PID of the PLC siemens s7 300 . if u can give me some advice or small example how ti tune a basic example that will be nice
again thanx for ur help 🙂
(4,370 Views)
Hi riki35,
I hope you are having a great day. I was reviewing your question and I gather several links that might help you obtain valuable information to accomplish what you would like to obtain. These links are the following:
http://zone.ni.com/reference/en-XX/help/370401H-01/lvpidmain/creating_memfuncs/#moremfs
http://zone.ni.com/reference/en-XX/help/370401G-01/lvpid/defuzzification_methods/
http://www.ni.com/pdf/manuals/372192d.pdf
https://decibel.ni.com/content/docs/DOC-16557
I really hope you can find the information valuable.
Luis C.
Applications Engineer.
(4,330 Views)
hi lucaso3 , hope you are doing well
really I thank you for your help and thank you for taking time to search things for me
I  will see the links you have posted
I 'll do my best to achieve this project. when I finish the project (hope so) I'll post how I did with details for the other users 😉
again thanx for your reply
(4,323 Views)
