tdms memory usage increases
I am using a tdms file to store and read back data for displaying on a graph.  There are seperate programs running, one for acquiring data and program control being displayed on one PC monitor, and the other displaying data on 6 selectable panes with waveform graphs on a seperate PC monitor.
Here is my general program operation.
I open the tdms file and use a global variable to hold the refnum.  I then write to and read from the file from multiple locations continuously while the system is running.
While doing this there is a steady increase in memory usage which doesn't go away when the file is closed, deleted, then recreated which was an attempt to clear the memory.  I am roughly losing 250MB of memory every hour the system is running.
Also I have a tdms file used for data logging which is opened and closed during every write cycle and I do not see the memory growth as seen when keeping the file open.
To test where the memory leak was coming from because my overall program is very large, I diagram disabled all of the tdms writes on the open file and no longer saw the memory usage increase.
Things I have tried are:
- Flushing tdms memory after writing or reading
- Closing file periodically, deleting it, then recreating it
- Tested only writing to file, disabled reading
despite these efforts the memory continues to increase.
This is a major problem because the client this software was created for needs to run tests for at least 24 hours at a time and currently that is not possible because the system eats up all the memory and labview crashes within something like 6 hours.
I am using labview 8.2, after seing that 8.2.1 hads some major updates to tdms functionality, I advised our client to upgrade but no change has been seen in the performance
Thanks in advance
Ryan
(2,931 Views)
Hi Ryantroz,
1) Be sure that you are not opening and closing the file within a loop.
2) Be sure that you are closing all references that you open.
3) Please use the Profile Memory and Performance tool to identify which VI is causing the problem.  Go to Tools >> Profile >> Memory and Performance.  Select Profile memory usage and Memory usage to view which VI is causing the memory leak.
Let us know how it goes.
(2,912 Views)
