tcp windows media player
Hi there, I am new to LabView and currectly doing a small revision that able to play windows media player through control panel. But I am getting an error when I take second action in my client side. Below is my problem.
(3,528 Views)
Hi KinniHan,
due to missing WHILE loops your VIs run only once!
So it is expected to get problems on "second action"…
(3,490 Views)
But I am using the continuouslyrun function. Which mean I must add a while loop in order to run more than once even though I am using that?
(3,449 Views)
Hi Kinni,
using "run continuously" is just for debugging purposes…
(3,445 Views)
Thanks for your advice but it is still not working after I added in a while loop and my problem occur on "TCP write" when I try to excute the second action.
(3,438 Views)
KinniHan escreveu:
What is the problem? There are lots of problems related to TCP Write.
Mondoni
(3,428 Views)
Hi, thanks for concern. This is the error I had during debugging.
Error 62 occurred at TCP Write in Untitled 1.vi
Possible reason(s):
LabVIEW: Serial port overrun error.
LabVIEW: The system caused the network connection to be aborted.
(3,418 Views)
