tcp read message
Hi Everybody
I have a problem with LabVIEW "TCP Read". I have developed a TCP server, that needs to process data message that arrive from a C++ appliacion, not developed my me. This application, sends a message with a defined format. That is:
byte 1: type of message
bytes 2 and 3: value of variable1 (unsigned int)
bytes 4 and 5: value of variable2 (unsigned int)
The problem is I don't know how to "extract" bytes 2 and 3, and bytes 4 and 5 to create an unsigned int variable. Does anyone know how to do it??
Thank you very much in advance!!
(2,959 Views)
Hello Esther,
TCP Read Returns a string as output, assumning that the person who did the "other end" of you TCP/IP comunication used a binary coded string, the following approach would work (Check annex).
Hope this helps,
Paulo
(2,952 Views)
Esther.Lopez wrote:...This application sends a message with a defined format. That is:
I suppose that you retrieve the message either as a string, or as a byte array. The attached vi shows how to convert to an appropriate format.
CC
Chilly Charly    (aka CC)
(2,949 Views)
Thank you very much!! Both messages have been very usefull for me.
(2,933 Views)
