tcp\ip
Is it possible to send and receive data using same port in tcp\ip???
(3,725 Views)
Yes,
 Check the LabVIEW example VI's  "TCP Communicator Active.vi" and  "TCP Communicator Passive.vi"  through the example finder
(3,698 Views)
Yes, it possible to use the same port to send and receive data if there are defined in the connection
18853iF603AB455863E61F
18855i2F7C92A75C6FB93B
(3,695 Views)
Hi ayusg,
what do you mean?
You can create a connection between two PCs on one specific port. If the connection is established you can send and receive data on it.
Mike
(3,694 Views)
Thanx for the help....i need to establish a connection between kuka robot (labview not installed on it) and my pc.Robot sends me an xml string with its current co-ordinates and i have to update those co-ordinates and send it back to robot when i do  that it shows "670" bytes written but its not reflected on robot side.This is a real time operation and on robot side os is vxworks  so do i have to use rt communication wizard or is it possible through normal tcp\ip vi.I have attached the vi which i was using....thanx again fo da reply
(3,680 Views)
