tcp ip
Good morning
I have the following problem.
I'm studying the examples simple client.vi and server.vi.
My problem is that a LabVIEW 8.2 VI implemented to acquire data and to control an actuator
should send to and receive from another application written in C + + numeric data using tcp/ip connection on the same local PC.
The c++ program and the labview program have to first send or receive data and then run some specific function.
I would understand if the above examples can be used to send and receive data in labview program and if the c++ application can work using the same port on the same pc
by means of the tcp protocol to send to and receive data from the labview application
thanks
(2,527 Views)
Answered here
(2,502 Views)
