tcp client server problem
I want to establish a tcp client server communication, as you can see the client has 02 WRITE blocks, the 1st one inside an even structure at startup and the second inside the while loop.
My aim is to first send a data packet for initial configuration (to plot a graph e.g.color type), the second WRITE will contain the actual data of the graph.
Is this attempt correct?
(2,809 Views)
have a look in the "Help"->"Find Examples"
and search for TCP, there you will find "Simple TCP.lvproj"
that should get you started
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(2,788 Views)
