tabs in exe subVI in LV2015
I have a VI that calls a subVI that has tabs.  I use 'SubVI Node Setup' to open the front panel when loaded.
I use Application builder to create an .exe of my VI.
When i open the exe on my target machine, the subVI opens but I cannot switch tabs.  With LV2014, I could switch tabs
Any one else seen this?
Grant
(3,387 Views)
Post your code, no idea why it would behave this way.
(3,380 Views)
Hooovahh - thanx for the reply.  I have proprietary information in a number of the 900 some-odd subVI files.  I'm going to have to strip that stuff out, see if the problem persists before I can post code.
It's frustrating because it worked fine in 2014 but not in the 'new-and-improved' version - same code, same build script.
(3,356 Views)
I removed proprietary information and made an .exe and it worked fine.  I put the proprietary stuff back in and it still works.  Problem 'solved'
(3,322 Views)
At any point, did you set the tab enabled state to disabled? This would let you switch tabs while the vi or exe is not running, but not when it is running.
(3,263 Views)
Good hint but, alas, I wasn't disabling the tabs.  I couldn't control them even when it wasn't running.  I've not be able to reproduce the problem - it works as expected now
(3,236 Views)
