table reference close
hi,
      how work table reference connection.in this my program close button event close the table reference than cick next and previouse button how it will change the table property.
Message 1 of 10
(5,052 Views)
hi,
         my example program...
Message 2 of 10
(5,044 Views)
I prefer to use Multiculomn listbox..
but try this
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 3 of 10
(5,017 Views)
Hi what do you want your program do?
in close event you close refnum link to table control.. so i not sure you can not use it anymore..
Message 4 of 10
(5,006 Views)
Ok but clean it Cat LOL
Message 5 of 10
(4,999 Views)
hi,
        i know close the reference is close the all table action. but how the change the next prorerty in table.bcaz table referece connection is ouside the while loop.
Message 6 of 10
(4,974 Views)
1/ check this vi
2/ what you try to do? change color of selected tab cell? if you use prev of next you select cell 0:0 0:3 why? to change them colors???
Message 7 of 10
(4,955 Views)
@AFLAMENT wrote:
1/ check this vi
Since the original VI was posted in version 8.2.1 I doubt the OP has access to 2014 which is the version of the VI you posted.
There is no need to close a control reference you didn't not open.  The control will stay in memory because it is in a front panel of a VI that is still in memory.  So just don't use the close reference.  Also know that the reference doesn't change, it is a by value not by reference, so you can use that same reference from outside the while loop in all of your cases, it doesn't change or close and should always work.
Message 8 of 10
(4,944 Views)
is good now?
i just make minor changes.. and link property node to panel>tabcontrol (keeping property)
Message 9 of 10
(4,933 Views)
hi,
       i just testing only use color i know this wrong.i want know about what is difference between table ref,TCP connection ref,Data base reference.
Message 10 of 10
(4,899 Views)
