table into excel file
i have made this programme to get my measured data in excel file(voltage at ch1,ch2 ratio ch2/ch1)only prolem left is this that i have to make different number of run for measurments but it open each time a new excel file but i want to get all run results in same one excel file without opening new one how i can do this????
best regards
rizwan bajwa
(2,902 Views)
Hi tizwan,
as long as all those subVIs from ole-excel.llb are missing we can't tell much...
General suggestion:
Open the original excel file, search for the last row of results, append new results in the next row!
(2,898 Views)
The subVIs were not included, but based on the names, it appears you are using some library that uses an OLE connection to Excel. Is there a reason for using this method as opposed to ActiveX?
Code comments:
  • Why a for-loop. You have a Stop button, which seems to imply you're intending a while loop there.
  • Do not initialize and close the serial port with each iteration. Open once. Close once.
  • Why the 3 loops at the bottom? They seem to make no sense for being there.
(2,895 Views)
