table color does not reset
My table (AVG SUM TABLE) is supposed to show entries less than zero in red. It has a small problem. The first time it works, but the second time the text color does not go back to black when I run it again.
It remembers the entries that were red from before. Based on my wiring below, the second time I run it, it should set the background color to light yellow, and the text to black, then perform the for loops.
BTW, I also used a flat sequence to force this order, but that didn't help.
(2,941 Views)
Accepted by topic author murchak
Hi murchak,
from what can be seen in your picture you
- only set one cell to "light yellow" background: ActiveCell=(2; 2)
- then you set the first 3 rows to background "light green"
- then you set some cells, depending on their value, to red. (Btw. there's a special "<0" function in the comparison palette!)
There's no place where you set a black background for all cells!
Maybe you should try ActiveCell (-2; -2) instead?
(2,940 Views)
Thank you GerdW.
-2,-2 did the trick. that's what happens when coding is done at 2 AM. can't believe I didn't see that.
(2,937 Views)
