tab control does not show up
It's not a video card problem. It's a corrupt control. Newer versions of LabVIEW are able to display it, but it's still messed up. Attached is the VI back-saved to 8.2 from 8.6 which managed to at least open it. You should:
  • Move the controls in the tabs out of the tab.
  • Delete the tab control.
  • Create a new tab control.
  • Move the controls back into the tabs.
What I would actually do is simply rewrite the VI. It's a horrendous mess.
Message 11 of 13
(710 Views)
Someone had to say it
Tim Elsey
Certified LabVIEW Architect
Message 12 of 13
(706 Views)
Better yet.  I ran a block diagram cleanup on it.  It doesn't look quite as messy, but is still a mess.  I like how you have controls that are wired to local variables of the same control, not just once, BUT TWICE!  Really make sure that the value of the control can't change.
Message 13 of 13
(686 Views)
