04-23-2015 07:35 AM
04-23-2015 09:46 PM - edited 04-23-2015 09:55 PM
Compare your code to Mikes. It does not look the same. It might be tough to compare since your LV is in German.
I don't see where you are using the Independent Labels boolean property.
You used "Seitenname" which I translate to Pagename which is probably the property Page Label. You should be using Tab Caption.
I have no idea what "unabhangbeschriftg" is supposed to mean. Google translate didn't understand it.
As Mike said, fix your code to use for loops and auto-indexing tunnels where you can. Elsewhere, don't take an array, branch it into 5,6 different wires. Lay down 5,6 different Index Arrays, and then wire a constant to each as 0, 1, 2, ...
Index array is expandable. Drag down the bottom border and you'll get multiple outputs from a singe array. You don't have to wire up any constants as they will be default be element 0, element 1, element 2, .....
04-24-2015 01:24 AM - edited 04-24-2015 01:25 AM
Hi RavensFan,
Seitenname = page label (error messages says: not writable at runtime…)
UnabhängBeschriftg = "Unabhängige Beschriftung" (yes, NI uses a lot of abbrevations in the property nodes also in the German LV version) = independent label
04-24-2015 03:18 AM
Hallo Herr GerdW,
Vielen Dank für ihren antwort. Wie kann ich diese fehler sortieren.
04-24-2015 03:23 AM
Hi hariss,
you don't need to "sort" those errors - you need to avoid them…
You CANNOT write to those "Seitenname" property nodes at runtime. Point.
Use captions ("Registerkartenuntertitel") instead of labels, especially as you already enabled them with those "Unabhäng…" property before!
(Cleaning up your code woulod be nice. Using autoindexing loops greatly improves code!)
04-24-2015 03:31 AM
Hallo Mr.GerdW,
Thanks for the corrections. I am not very good in German, So wasnt able to identify the correct property node. Now it works perfectly. I just was trying to check if things work and then i will clean up the code as per your suggestions. Thanks alot
04-24-2015 03:32 AM - edited 04-24-2015 03:33 AM
Hallo Mr.RavensFan and Mr.Mike,
Thanks for the suggestions. Now its working fine
