system time from a gps receiver
Hi. I use Labview 8.6.
I managed to output data from a Garmin GPS Receiver (on serial port). OK.
Now i want to synchronize the GPS with my PC, to have the same time.
How can i do that ?
(3,013 Views)
Accepted by topic author dsasorin
You can try this
http://digital.ni.com/public.nsf/allkb/459C9E8DCD8488B686256E3200625E54
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,001 Views)
windows machines can set the time from the command line, which may be simpler than calling a dll:
one way to do this is with the "time" command.
http://ss64.com/nt/time.html
looks like you get hundredths of a second.
simply send "time [newtime]" to a system exec function.
-Barrett
CLD
(2,990 Views)
Go to Help example finder. Then search for EXE and select the Calling System Exec.vi example. Note since time is Built-in command, add the cmd /c before the command. Else it will not work.
(2,978 Views)
