system exec
I want to start an application with the system exec command.
Sometimes I get the error code 2:
"Warning 2 occurred at an unidentified location.
Possible reasons:
LabVIEW: Memory full.
or
NI-488: Write detected no Listeners."
I can not specify when this error occurs. But I can not believe that the
memory is full.
When I call the application (which I want to call from Labview) not with the
Labview system exec command but from a windows command input, it always
works fine. Besides the application - I want to call with the system exec -
is not very large.
Used system: LV 6.1, Win2000
Does anybody know this problem or is there another way to make a system
call?
Max
-> max.weiss@web.de / maximilian.weiss@celpat.de <-
-> Max Weiß * Eulenweg 2 *
76356 Weingarten * Germany <-
-> Fax/Voicebox: 01212-5-105-70-879 * Tel: +49 162 9114507 <-
-> ICQ: 123429315 * DB 8 MWE <-
Message 1 of 11
(12,040 Views)
Are you running an application in 6.1 that you built in a previous version? The only instance I have ever heard of this happening in was when a LabVIEW user used a 5.1 VI in 6.02 and it gave this error. They ran a mass compile and I believe that this fixed the problem. If you have not already done so, make sure you do this.
J.R. Allen
Message 2 of 11
(12,038 Views)
Definitely not - but I made a mass compile and nothing changed.
Max
Message 3 of 11
(12,038 Views)
System Exec returns the windows error code - not the LabVIEW error code. The
Error 2 means, that the system cannot find the specified file.
So please check the path to the executable.
Martin
Message 4 of 11
(12,037 Views)
The
Thanks a lot. I already wondered that I received the same error code 2 when
the file path is not valid. ;-/
Anyway, I still get this error but I think I have to check my file system.
I will let you know it when I have solved it. 🙂
Thanks a lot
Max
-> Max Weiß * Eulenweg 2 * 76356 Weingarten * Germany <-
Message 5 of 11
(12,038 Views)
Have you solved this problem. I think I am having a similiar problem.
Message 6 of 11
(12,038 Views)
Message 7 of 11
(12,039 Views)
Yes i am getting the same error.  I tried running a visual basic program with the windows command line, it works fine.  When i run it in LabView i get the same error.  Does this have anything to do with the OS?  On the help page it mentions to put cmd/ c before the rest of the command line.  Without this i don't get an error, but the program doens't do what it is supposed to.
I am using LabView 8.0 and the program was coded in Visual Basic 5, compiled in 6.0.
merci
Message 8 of 11
(11,499 Views)
Hi teky,
Like you mentioned, to fix error 2 you saw you need to place a cmd /c  with the System Exec.VI The error normally occurs when trying to run a command prompt window specific command such as dir or set. Using the System Exec VI is not the same as typing a command into a command prompt window; instead it is like typing a command into the Run window.
To run command prompt commands from the System Exec VI, execute the command prompt window first with the following command:
cmd /c
For example, to run the DOS command dir, use the following string as your command line input into System Exec.vi:
cmd /C dir C:
So the real issue is how your program does not do what it is supposed to do.  You might post a little more information about what your trying to do and what the VB program is supposed to do.
Steven B.
Message 9 of 11
(11,476 Views)
I was getting the same error with system exec and none of the suggestions on this page or other ones I saw would fix the error. Though for me I noticed that the VI used to work, but had suddenly stopped working. The cause was that I had moved the folder containing my VI and my executable (same folder).
So I just recompiled the VI (make some minor change or use save as) and it started working again.
Message 10 of 11
(11,257 Views)
