system exec.vi
i have tried to run an exectable(ex:Calc.exe - which is for system calculator) using system exec.vi..
 But i'm getting the error as.. Can any one know how to rectify this problm..
18453i512BDE8F0EB4F567
Message 1 of 8
(5,101 Views)
Hi suresh,
it runs fine for me:
18455iBFB92C6CF2BAF759
You may try the command line "cmd /c calc.exe" too.
Edit:
Did you give the command as "calc calc.exe" as your error dialog says?
Message 2 of 8
(5,096 Views)
Works fine for me.
See image below:
Message 3 of 8
(5,094 Views)
Now i'm getting calculator window...
i have one third party exe in the name of DragonPCI.exe which do simply read and write operation
in a FPGA board..
when i give DrongPCI.exe in the command line it shows me the same error..
18457iA37266BFEE9A6DD2
the same thing is happening for acrobat reader also..
18459i96C077A67F6BE512
Message 4 of 8
(5,086 Views)
Hi suresh,
when those programs aren't in the search path of Windows you have to set the complete path for the command!
Message 5 of 8
(5,082 Views)
Thanks dude..
Now i'm getting the required result..
Can i do i/o operations using LabVIEW on any other third party pci devices using their DLL's..
Message 6 of 8
(5,076 Views)
Yes, dude.
Message 7 of 8
(5,073 Views)
If you have dll's (API's), then you should use the Call Library Function Node.  Same palette as the System Exec.
Message 8 of 8
(5,039 Views)
